My Denon AVR 3801 is causing a buzz/hum using the pre-outs.
I'm getting it looked at soon to see if its worth fixing.
In the likely event that I need to replace it what are my options?
It is used to drive 3 speakers: a centre speaker & 1 pair of surrounds/rears
Pre-outs to my Quad amps for the front speakers
Audio decoding done by my CA 751BD to external inputs on the Denon
It does not need to do anything else
I have searched for an answer but it seems that the only AVR's with external in & pre-outs are the higher end ones. I don't want to spend that much. I don't mind second hand but you don't know what you are getting and how long it will last - it might end up more cost effective to have mine repaired. I could just keep using the Denon until it fails but that risks damaging something else depending on the fault. Or I could use a cheap AVR and speaker switches. I could just go 2.0 for movies but I think I would miss surround sound. Any solutions that anyone come come up with?
