Rega RP3 / B&W DM603 S2 Amplifier ?????
Hi there. I have an RP3 with the Elys fitted, a set of series 2 DM603s and a crappy old amp.
I listen to all sorts from Miles Davis, Metallica, Beefheart, Beatles etc
Any suggestions on a suitable amp for this set up ??
Don't mind searching for pre owned stuff. What should I be looking out for and what differences do things make ?
I knew it would be a slippery slope once I got the Rega !!!!!!!
Cheers......................
What is your budget? What kind of sound are you looking for?
Why not stay with the Rega brand and get an used Rega Brio 3 for under £200? It comes with a good Phono MM pre-amp too...
Hi do-hat
A NAD C370 will do the job nicely 🙂
All the best
Rick @ Musicraft
