Rega RP1 or Project Essential II
Azzer31
Looking for some advice on getting a new turntable. Both the Project Essential II and Rega RP1 get 5 stars and there doesn't seem to be much to choose between them, price seems similar too around £210-£225.
I'm connecting to an existing HiFi system I bought a few years ago and want to play my old vinyl from the 80s/90s.
I like the fact there is a performance pack for the RP1 which I could get at some point in the future but any advice on which of these two is better or are they too close to call and I just go with my instinct?
Any help appreciated.
Aswad
Azzer31 said:
Aswad
To be honest there is little to choose between decks of this price, if you can stretch budget a bit the Project Debut 2 is a much better deck, otherwise just go with what you think looks better.
And I wouldn't contemplate the £85 performance pack as all you get is a different belt ( which on it's own is worth having) a wool mat and a different cartridge. The cartridge is still poor and not worth having if your old one is passable.
Better to save the money and upgrade to a better cartridge later.
jimbofisher
131
81
18,670
Azzer
Does your existing amp have a phono input? If not you will need to add a phono stage in to your budget.
Otherwise I agree with the above.
