Rega Planar 3 + RB300 + AT 440MLa
Jason36
427
After advise on fitting the AT440Mla cartridge to an RB300 arm on a Planar 3.......
Are spacers required to lift the tonearm or can the cartridge be fitted as standard without any mods required??
floyd droid
39
Not a clue Jason. However give your Elys a measure up and compare it to the AT. Their specs are available on tinterweb but Rega are as ever a bit cloak and dagger in regs to their carts.
No luck on the vinyl engine i guess
floyd droid
39
Chebby. Am i going insane or is your post,how shall we say,a tad tongue in cheek ?. Lol.
Because i can find zip in reference to the carts size.
chebby
1,246
14
19,195
floyd droid:Chebby. Am i going insane or is your post,how shall we say,a tad tongue in cheek ?. Lol.
Exactly.
It was a challenge to gregory to find the details he claims are on Rega's website.
(I was the one going insane reading that webpage about 20 times. I even brought it up in a different browser, just in case!)
floyd droid
39
Phew i can put the meds away then. I thought for a second i was missing something but had an inkling where you were coming from,but i had to clarify. Ta mate.
gregory
45
I stand corrected, all the specs are there apart from the height, if it's any help 14mm, i suppose your going to ask how i know now.
gregory
45
Sorry to the OP, a 2mm spacer should be ok but i wouldn't bother, i never did with any cartridge i had with a Rega, i know Chebby used an Ortofon 2m red with his [go check if you dont believe me] but the 2m may be close to Regas own height of cartridge.
ASK THE COMMUNITY
