REGA APOLLO CD PLAYER
Just purchased a REGA APOLLO CD Player which has a two pin socket yet issued with a three pin mains lead.
The connection i find is a bit fragile,anybody with a solution that could help i would be grateful.
Eh? 2 pins CD player side? If you're in the UK that's normal. Try a new mains lead if you think there is something wrong?
It's not uncommon for products with an IEC (3 pin kettle type plug) to only use two of the three pins. You can safely use any IEC mains cable with the Apollo.
Should be fine. Enjoy the apollo, its a fantastic cdp for the money
