Rega and rock ´n roll
ruivasco
11
Hello to all,
I like to listen rock like Nirvana,Tool,Flaming Lips and so on. Some folks says that Rega is better for Jazz. What do you think?Should I buy the Rega DAC or should I choosen another that suits better my preferences for Rock ?
CnoEvil
556
11
Another dac worth checking out is the Musical Fidelity M1......listen to both and buy the one that you like best.
ruivasco said:
Hello to all,
Hi ruivasco
What source component/s, amplifier and speakers do you use?
Btw, the Rega DAC also knows how to rock :)
All the best
Rick @ Musicraft
ruivasco
11
All the best
Rick @ Musicraft
A Densen and a B&W
All the best
Rick @ Musicraft
A Densen and a B&W
Hi ruivasco
Thanks for your reply.
The overall tonal presentation and the quality of performance of the Rega DAC should work well your amp and speakers.
All the best
Rick @ Musicraft
