Recommended 3.5mm to RCA interconnect?
Scot1970
15
Hi there,
I would like to connect my Chord Mojo to my Arcam A19 amp.
Can you please recommend a good quality 3.5mm to RCA cable, one that hits the sweet spot of not short-changing the performance of the Mojo but also not breaking the bank?
Thank you.
Scot.
chris661
191
116
270
I'd say use anything except the really really cheap stuff which won't have adequate shielding.
Spend £5, and you'll be fine.
Chris
Reactions: KT66
abacus
378
130
19,070
Reactions: iMark
Dom
676
180
19,070
I think cables make a good enough difference to warrant the outlay, Bill. However spending over £100 would probably not something I would do with my current setup.
Al ears
Moderator
I would suggest you either buy cheapish and replace it when it breaks or buy one with good build quality that will last.
The Audioquest already mentioned seem to be well built.
britain4
40
I use the Audioquest Tower and it's absolutely fine. It IS better than the el-cheapo one I also have, in A-B tests. The Atlas interconnect I use for my CDP was 10x the cost if not more, and I strongly suspect you're running into diminishing returns above the Tower.
Please take this with a pinch of salt, I'm not able to A-B the two from the same source.
chris661
191
116
270
So what you're telling us is that Source A with Cable A sounds better than Source B with Cable B.
Not sure I believe it's the cables making the difference here...
Chris
britain4
40
Chris
No, have another read, that’s not what I said at all. Both cables make improvements but I suspect very similar - can’t compare directly though so again, take with a pinch of salt :)
gasolin
718
111
19,070
No less than QED Performance J2P 3.5mm mini-jack to 2 RCA Cable (Graphite)
Unfortunally they don't make anything better like the performance 40i or a reference cable
ASK THE COMMUNITY
