The sub has to be precise, compact and not to expensive and work with the marantz pm 6005.
Thanks Guys.
Thanks Guys.
Chr78 said:The sub has to be precise, compact and not to expensive and work with the marantz pm 6005.
Thanks Guys.
dakchi said:Sorry to jump in. Quick question: how would you connect the PM6005 with a subwoofer? it does not have a pre out or a subwoofer output
basshound said:Hmm, That didn`t work,tried to post a diagram,Oh well go here http://www.bkelec.com/HiFi/Sub_Woofers/gemini_manual.pdf and look at page 3 and it shows you how to connect a sub with a high level input to your amp.
JamesMellor said:In the box in the attic ?
"Inputs Stereo Line In (2x RCA Phono)
Speaker Level In
(5m cable supplied)"
It would not be easier , the supplied cable would have three cores proberly , L/R/G you connect these to the speaker terminals then adjust the gain and xover to match your speakers but this would remove your sub as a LFE channel and use it on the low freqs on your main stereo speakers only , so x.1 to x.0 no subwoofer on your amp set fronts as large .
James
dakchi said:basshound said:Hmm, That didn`t work,tried to post a diagram,Oh well go here http://www.bkelec.com/HiFi/Sub_Woofers/gemini_manual.pdf and look at page 3 and it shows you how to connect a sub with a high level input to your amp.
Thank you basshound. Where can I find a cable for the high level input? I have a B&W PV1
I use the subwoofer with my AV amp which has a pre out. Would it be easier (better?) to connect the AV amp with the the hifi amp through the preout?
dakchi said:JamesMellor said:In the box in the attic ?
Speaker Level In
James
Thank you for the info James. I think that I lost this cable. I have to buy a new one. I can't find it anywhere in the internet
basshound said:dakchi said:JamesMellor said:In the box in the attic ?
Speaker Level In
James
http://www.ebay.co.uk/itm/Neutrik-Speakon-High-Level-Lead-for-REL-MJ-Subwoofer-/370663550208?pt=UK_AudioVideoElectronics_HomeAudioHiFi_HiFiSpeakers&hash=item564d44ed00
