I bought a 160Gb classic iPod recently and have just finished loading all my stuff onto it. I find that I have some spare capacity and would like to re-rip some stuff at a higher bit-rate (originally it was 160 - I would like to up this to 320 now).
If I do this and replace the 160 files on i-Tunes with the 320 ones, will the 'sync'ing process be smart enough to detect that these are different files and copy them to my iPod and overwrite the old 160 ones there? Or does the software just compare say the artist and song name for example and if they are the same then do not execute a transfer - thus leaving the old 160 file untouched on the iPod.
If that is the case I guess the only way to force the new 320 files onto the iPod is to firstly delete it on I-tunes, sync, re-rip at 320 and re-sync ?
Any suggestions ?
Thanks in advance.
Brian.
Any suggestions ?
Thanks in advance.
Brian.
