steve_1979 said:As the title says.
Can anyone recommed a good cheap one?
Overdose said:steve_1979 said:As the title says.
Never had the need, but Google is your friend.
What are they for?
Overdose said:What voltages are the DM5s designed to work with? They don't seem ideal if they need an attenuator to get the best out of them.
It might be an idea to know the output voltage of the Pc at min and max settings. You could check it out with a multimeter. If the voltage is unusually high, ie above 3V, it might explain the need, particularly if the DM5s are designed with a max 2V signal in mind.
A -10dB attenuator would probably be a good start, but would an analouge volume control not attenuate enough anyway? Seems a bit odd to me.
Overdose said:It's a pity the ODA wasn't finished.
steve_1979 said:Oh and in case anyone is wondering... these DM5's sound absolutely wonderful. *yahoo*
John Duncan really owes it to himself to have a listen to a pair. They are far better than the Neutron 5's . I'm sure you'd love them JD.
davedotco said:steve_1979 said:Oh and in case anyone is wondering... these DM5's sound absolutely wonderful. *yahoo*
Have you asked the nice people at Epiphany if they can reduce the main output by 10db or so?
A number of people have expressed reservations that the DM5s are unduly sensitive so you are not alone in this.
steve_1979 said:davedotco said:steve_1979 said:Oh and in case anyone is wondering... these DM5's sound absolutely wonderful. *yahoo*
They do seem very sensitive, although I don't know how they compare to other active speakers in this respect. I was hoping to be able to use the PC volume as a temporary fix while I save up the money for a proper pre-amp. Using the headphone output works perfectly though so I'm fine with that for now.
MajorFubar said:Have you ever thought of buying a cheap two or four channel passive mixer? £25 or less. Basically a box with pots and some sockets. Seems to be just what you need.
davedotco said:Steve...
Just checking but I assume your dac outputs the usual 2 volt Red Book standard?
The volume settings in your media player seem awfully low, you should check that there is nothing adding extra gain in your computer.
steve_1979 said:davedotco said:Steve...
I have no idea what the voltage output on the DAC is. There are probably some specs for it somewhere on the internet.
When using the headphone amplifier as a pre-amp it all works perfectly. I have the PC volume set at 100% and have all the control and adjustment that I need using either the volume on the headphone amplifier or the volume in Media Player. It works a treat.
davedotco said:steve_1979 said:davedotco said:Steve...
Excellent.
Sounds like it will work beautifully with any variable output dac/preamp but will be a problem vith anything with a 2 volt fixed output, the analogue out of an AEX should work though, that is nowhere near 2 volts.
steve_1979 said:I'm running them of a Behringer UCA202 at the moment. It works a treat and without bothering to do in depth comparisons it seems to sound the same as the O2 DAC. I'll continue using it for a while until I upgrade because I can hide it out of site unlike the desk top O2 DAC which needed the cable plugged into the front which is irritating.
steve_1979 said:davedotco said:Presumably you using the headphone out on the UCA202 to get a level match?
Yep.
davedotco said:Read about your experiences with the subwoofer elsewhere, interesting as always. My own thoughts would be to go with the ADM9 and forget the sub entirely. Like you, I like a bit of dub, but can manage without the subteranean bass, just sounds wrong at domestic levels anyway.
For most music listening I use a sub to gently extend the bass without overdoing it.
But when listening to rave music or play computer games I use the subwoofer like a graphic equalizer for the bass by raising the crossover point and increasing the volume so that is shakes the whole room even when listening at moderate volume levels.
davedotco said:steve_1979 said:davedotco said:Presumably you using the headphone out on the UCA202 to get a level match?
Yep.
I have no interest in anything bar playing music on my system. I have never been happy with the integration of any sub in my various systems, my preference for really tight, fast main speakers, seems to make that really difficult.
I will, at some point make the effort to try the latest ADM/sub setup, it's really not that expensive as a system and what I have heard of (mostly earlier) ADMs I have liked a lot. I don't do big orchestras or much in the way of deep bass, so I am guessing, mainly from what I have read, that the 9RSs will do me fine.
