Rca cable for my hifi system
Hi ,
I am ending my hifi system , everything is ordered , but i have some hesitations about the rca cable : i've ordered a 8m audioquest evergreen , but now i checked some tests and what a hifi rates it 3/5 stars , with a lot of inperfections. I can cancel the order for these , and take another rca cable , so this is why i come to this forum : what should i do
- i keep this rca cable ?
-i order another ?
So , if this last choice would be better , what rca cable would you advise me , for at least 6 meters length and under 100e ?
My system is :b&w 683s2 , nad c370 amp and cambridge dacmagic 100 in order to play my music from tidal.
Thanks , Andrei
chebby
1,253
26
19,220
Andrei Baicu said:
It's a rca cable that goes from my dac which is near my pc , to my amp which is in the middle of the room
Ok. In that case i'd invest in a 6 metre optical cable and a short RCA pair.
Or (if USB) a combination of a USB cable up to 5m (maximum) then a 1 - 2m RCA pair.
Either way, let the digital part of the distance do the 'heavy lifting' and keep the analogue portion to a minimum.
Keeping the DAC's PSU off the same mains sockets as the PC is usually a good idea too.
