Apologies if I've missed the answer to this; what is likely to sound better, a £350 amp or CDP with a 4 star rating, and £700 amp or CDP with a 3 star rating?
plastic penguin said:Why the question? If you can give a few more details, we (I) can be more specific.
Andrew Everard said:Yes, we've been round the 'global ratings' track many times on the Forums, but the fact remains it just wouldn't work: the whole basis of the magazine is to show readers what are the best products at whatever price they can afford, and saying to them 'sorry, pauper - you can only afford a two-star product' would be less than helpful.
Lee H said:Andrew Everard said:Yes, we've been round the 'global ratings' track many times on the Forums, but the fact remains it just wouldn't work: the whole basis of the magazine is to show readers what are the best products at whatever price they can afford, and saying to them 'sorry, pauper - you can only afford a two-star product' would be less than helpful.
Yep. I've bought 5 star products knowing full well that they're not the best money can buy, but the best that I can afford.
Andrew Everard said:The whole basis of the magazine is to show readers what are the best products at whatever price they can afford
Sizzers said:I fully understand how the rating system works, but wouldn't it be possible to give a parallel rating based purely on performance rather just on the perceived value for money?
Andrew Everard said:Sizzers said:I fully understand how the rating system works, but wouldn't it be possible to give a parallel rating based purely on performance rather just on the perceived value for money?
Again, we've discussed this, but the feeling is this would only confuse.
Sizzers said:Would you mind if I asked what criteria you use for awarding a product 5 stars based on its "value for money", when another product you might award 4 stars to in the same test is clearly the better product? Sure, in it's given price range it might be £50-£100 more but perhaps a more detailed explanation would be helpful IMO as to why you consider it doesn't give "value". Hope that's made sense!
Andrew Everard said:Sizzers said:Would you mind if I asked what criteria you use for awarding a product 5 stars based on its "value for money", when another product you might award 4 stars to in the same test is clearly the better product? Sure, in it's given price range it might be £50-£100 more but perhaps a more detailed explanation would be helpful IMO as to why you consider it doesn't give "value". Hope that's made sense!
I'm not sure it does, but I think you've answered your own question. It's about sound (or vision) per pound – slways has been, always will be.
lindsayt said:The star ratings are only a very useful guide.
What counts is your ears and how you think a particular component sounds in your system.
