Racks
Greenwich_Man
106
32
18,620
Can you recomend a rack for a budget system please. I have...
Project turntable
Denon Tuner
Nad Amp
Pioneer CD Recorder
Yamaha Tape Deck
Nad CD Player
Thanks in advance
Would it help if I listed the model numbers?
Project Debut 2 Turntable; Denon TU260L Mk2 Tuner; Nad C320BEE Amp; Pioneer PDR-609 CD Recorder; Yamaha KX-439 Tape Deck; NadC451i CD Player.
I think there are very few of us whom would hesitate to recommend the Atacama Equinox series!
Loads of excellent quality stands going very cheap on E-Bay. Have a look.
"How much do you want to spend"
I want to spend as little as possible - my intention is to keep an eye out on e-bay for what you folks suggest.
I don't have a rack - but I saw on this site that one is really needed
Soundstyle do decent solid racks n can find them very cheap on ebay , i got my 5 tier soundstyle 5 for £50 , deffo helps =]
m0172uk:Soundstyle do decent solid racks n can find them very cheap on ebay , i got my 5 tier soundstyle 5 for £50 , deffo helps =]
Thanks so much - I'll keep a lookout for Soundstyle in my area
Well I did it - I bid for soundstyle and got it for £50 - looking forward getting it home and setting up - expect it will be a couple of weeks before all is in place as the wife wants to redecorate while she is on hols next few weeks (she liked the look of it too!!)
So thanks folks for ALL your help.
