R100 speaker stand advice
p_m_brown
56
Hey all,
I'm still really enjoying the R100s and was wondering if the cheap atacama nexus stands they are sitting on are doing them justice.
Is it worth upgrading, if so, what do you recommend? Or maybe I should spend my cash on a few beers and a bunch of new CDs?!
If the stands are heavy,or if hollow they are filled then i would imagine they are fine(take it they are on the iso pads?)🙂
They should be fine, but you may want to experiment with filling with sand (kiln dried) or cat litter, try 50% then keep adding to see the best level.
