Big Chris:Gerrardasnails:Big Chris:
Just wondering how they stack up against each other.
I was looking at aroun d£15 per metre (I need twin 3 metre runs), which is fine for the Revelation, but the XT400/350/300s can be had for not far off this, especially second hand.
Any thoughts?
Any of those BC for your speakers. I have the Odyssey but feel that would be overkill for the MT sats.
Nah. I'm keeping the S.A XT for the M1s. The upgrade cable will be used for my 602 S3s until they're replaced. I currently use some Silver Anniversay Biwire (pre-XT) in a bi-amp configuration.
I know other have recommended other cables, and I have thought about the Atlas Hyper 2.0 as well as the Chord cable.
Might just hold out until I replace the speakers, then worry about which traits I require from a new cable.
Aha. Sorry mate, I didn't read your post properly. You can get some good deals on ebay, try them and sell them on if you don't like them - quite fun to play and doesn't cost a lot.
