- Aug 10, 2019
- 2,556
- 4
- 0
I need some advice on speaker cable. I have a Marantz 4001 amp; Marantz 5001 CD player; Project Debut II TT and Mordaunt Short 902i speakers.
I was currently using QED silver anniversary bi-wire cable to connect my speakers, but I now need longer cable (having just moved my system). My budget is pretty tight and I can't justify spending £50+ on speaker cable.
Does anyone know if QED classic 79 strand cable would be perfectly good enough for my system?
Or any other cables anyone could recommend? I have a budget of about £20 - £25 to spend and I need about 10 metres of cable (2 x 5 metres). I could do with some bananna plugs too.
Not sure if bi-wiring really makes a difference at all, so not particularly bothered about buying bi-wire cable again.
Hope someone can advise.
Chris.
Chris.
