Q acoustics 1010i or WHARFEDALE DIAMOND 9.1AV???
Hi i need some advice on which system is better, I can get the 1010i for £450 and the wharfdale for £650 is it worth the extra £200 for the wharfdale?
Thanks Matt.
There are two different speakers you take for comparison. I think, Q1010i should be compared with D9.0, and Q1020i with D9.1, no?
Anyway, both of them are good, depends on your budget.. theoretically, the more is better
How do the 1020i compare to the 1010i then?
Much difference when added to the home cinema and/or stereo playback when used with an onkyo 606?
Anyone know......
