PS3 to stereo
josh.armstrong989
I'm unable to connect my PS3 to my stereo.
When I've used female to female connectors, the cables are loose and don't pick up a decent sound quality.
The problem is they're both different types of cable. The PS3 audio is RCA (white, yellow, red) and the stereo is 3.5mm (white, black green).
I can't plug directly into the monitor, as there are no ports for external audio.
How can I connect the stereo to the PS3?
Any suggestions would be appreciated. With thanks. :?
professorhat
992
22
18,895
The problem you've got is those speakers are designed for a PC, which needs those three 3.5mm cables to connect it. You could try a converter like this, but having never used one, I couldn't guarantee it will definitely work.
EDIT - sorry, that's US Amazon - UK version here.
