PS3 or Blu Ray Player
smarky
45
Hi, Ive just brought a Pioneer 428XD, And i am looking to get a Blu Ray Player for around £300-£350 Mark. Is it worthwhile just getting the PS3 or a separate player, if a separate plyer can you recommend any?
Thanks.
If You wish to make use of the fact the PS3 can also play games then go for the PS3, other wise I would go with the Panasonic BD30.
If it's purely for movies, then the clear otion would be a dedicated blu-ray player, but if you've got gaming in mind too, then it would be the PS3.
