projector screen black border.
ibl0010
59
Compare to few years ago TV now aday are less chunky and have thin bezel but not much has changed in the projector screen world. I mean; projector screen still have 2 to 3 inches border so my question is that what are the advantage of projector screen having a thick border than a thin bezel. If I go the projector route am looking to make a DIY screen that is thin and look more like a big plasma on the wall than a projector screen.
Never seen any borders that wide on a projection screen except at the top if you have to pull it down to get a good screen height.
Black borders are ideal for presentations as it allows you to focus better on the presentation; also it is easier to produce a good screen with a wider boarder than a narrower boarder.
If you buy a fixed screen that is permanently fixed on the wall, then most have a narrower surround.
Hope this helps
Bill
Hope this helps
Bill
I am actually thinking of making my own screen smiliar to the black diamond zero edge. I want the large flat pannel plama like style of screen. I tink the black diamond zero edge is only 3 inches thin.
Do you have an idea of a screen material to screen a screen like black diamond zero edge. Don't know why but i have the idea of perspex or plexiglass in my mind stuck to a screen material
