Projector or TV?
Mark Webb
22
I am intending to creat a new TV room. How good are projectors or should I stick with a TV for the best picture quality?
The best picture quality comes from a projector but at a cost. They are different options really but I would opt for the big screen all the time if you watch films/play games.
Mark Webb said:
Can we get a decent picture for £3K, or does it mean big bucks?
Yes you can, why not check out WHFS&V awards on projectors for 2011, you should find one around or under three grand.
Seconded 🙂
If you're selective about your viewing - eg predominately HD TV, movies etc - and have the screen/space for it, nothing competes with a projector for immersive experience.
I wrote this a few years back now, but projector performance-per-pound has only increased:
http://www.whathifi.com/blog/projectors-for-life-not-just-for-cinemas
That budget will get you a great picture. The latest models all start near £3000 so depending on your screen requirements you should be close to that figure.
Thank you so much to all of you for the very useful info. Thats a great article Clare. Some of you mention "if you are into films and sport" its a good option. Does this mean that its not an ideal way to watch every day TV?
Would the ideal be to have a flat screen tv with a screen which drops down in front for viewing films maybe? Budget allowing....
If you can get a great picture for under £3K what on earth is the point in buying a SIM at £30K?? :?
