Project SB
kitkat
162
I have upgraded the stylus that came with this model (OM5) to a OM20 to get a bit more detail and it works fine without any changes to the weight etc but I have thought about going to a OM40 which is as far as I can go on this model, but it costs nearly as much as the deck at £140.00 and my hi-fi shop told me that it would not make that much difference do you think I would hear much difference or is the OM20 good enough for this deck.Thanks.
gregory
45
hello,your om20 is more than good enough,you seem to have an honest dealer there ,it's only when you upgrade the tt that you should think about a more expensive cartridge.dont forget a new stylus needs a run in period so your om20 should sound a lot nicer after about 20 hours of play.good luck,gregory.
