Dear ALL,
Just replaced my old 8200CD & 8200A with the Oled version of 8200CDQ plus the 8200P to my ProAC Studio 140 MkII. Interconnect: Chord Company Chorus Reference & speakers cable w/ Chords Odyssey2 bi-wire.
I can hear the performance in term of sound quality is much better with new these new equipments, unfortunately there're couple issues that I need explanations. ALL of the below issues happens in ON status when the disc is not playing.
1. If I activated the 8200P first before the CDQ (I know I was supposed to power-up the CDQ first & reverse the process when shut-down), there was hum coming from from speakers. With the 8200A earlier this never happenned. Is it normal?
2. The hum dissappears when the CDQ is activated but still leave a hiss which is audible from 1 meter distance. Is this also normal?
3. The hiss is much less (but still audible with ear around 10cm from the speaker) when the Pre-Amp of the CDQ is set to "Analogue".
4. On the CDQ manual, the factory default setting of the Pre-Amp is "Digital" & said it's superior & for Digital Sources. What does this "Digital Sources" stands for? Only for digital file from computer or USB or from standard CD too? I assume that a CD also a digital source.
5. I only plays CD from this player, not using any digital file from computer. Should I also use the Digital Pre-Amp? If the selection of pre-amp is based on individual taste, I prefer the Digital Pre-Amp but the level of hiss really annoying.
Just to make it clear, those problems never happened w/ my previous old 8200CD & 8200A combo. All supporting equipments remain from my previous system, I only upgrade the CD player & amp.
Thank you in advance.
