maka12:
thanks for your reply john
why do you think it says it is outputting at 1080p24 when its selected on auto, when i bought the tv i was told it would be great for blu ray and that it was 1080p compatible,( this plasma TV supports up to 1080/24p video format, the perfect digital film format that will be available on Blu-ray discs and other high definition media(. the last sentence was from pioneer web site on my plasma, when i spoke to pioneer earlier today they told me i should be able to output at 1080p 24, thanks
No Problem Maka,
Unfortunately, while the display is 1080 24hz compatible (i.e. can accept the signal) but it cannot output 1080p. The person at Pioneer must be mistaken as there physically are not enough pixels in the display to output a 1080p resolution.
Your TV was released around the same time is mine. A time when the HD resolutions were somewhat confusing and many manufacturers (such as Pioneer) were badging sets as 1080p compatible as they can accept the 1080p signal, although the viewer will never see 1080p (this was not badged very clearly, and you had to look at the native resolution of the set to see if this was the case). Whether this was intentionally misleading or not, I do not know (although I have my opinion), but it was definitely confusing for the consumer.
It is still a good set though.
