- Aug 10, 2019
- 2,556
- 5
- 0
Hey guys,
Can anyone comment on this pairing pls ?
The living is around 4X5 m and I'd be seated around 2.5m from the loudspeakers. Would the ATC SCM19 be a good match. I understand the ATCs are quite power hungry so would the Primare be a good enough amp to drive them at 100W/ch ?
Or shall i get the SCM11 ? Are they very different speakers ? The 11 falls within the budget but for the 19 I'll need to stretch a bit but if it's worth it then I'm prepared.
Quite a number of guys recommended the PMC Tb2i and Dynaudio Focus 110 and I auditioned the new PSB Synchrony Two B and the B&W CM5.
They're all good and they're all cheaper then the ATC (except for the PSB) and I guess it's safe to go with any of these ultimately choosing over preference of sound character but the only thing is that they're all rear ported. And i won't be able to move them away far enough from the front and side wall for proper placement ( max of 0.5m ) .
Thus ATC came to mind (since it's a sealed design). Much appreciate the suggestions guys.....
Cheers......
Cheers......
