- Aug 10, 2019
- 2,556
- 5
- 0
As you may know, I have been making many decisions lately, I have cancelled 3 orders so far, I really ned to make my mind up soon! Ok, Is it better to get a pre amp, then a sepearte amp to match it, or an intergratd amp? Intergrated seem much better value for money! I found the new Sony STR-DA6400ES, not the STR-DA5400ES for £1499.99 reduced from £2,000 I believe. Or should I pay £400 more and get the RSP-1570 as the pre amp, with the RMB-1565 as the amp. The only disadvantage with the Rotel is that it is only 100 watts per channel at 8ohms, while the Sony is 120 watts per channel at 8ohms, also the sony has auto-setup, but the Rotel doesn't!
I will be using a B&W PV1 sub, with 2 683's. (I will upgrade to 5.1 later in the year).RSP-1570
