Power switch with remote on and off ... but not just on/off toggle
AlmaataKZ
297
8
18,895
I want to have remote control for a set of active speaekrs and sub and currently have them powered via savasockets - these can toggle power on/off with a single infrared remode code.
because savasockets work as a toggle command as opposed to a discrete command (the one allowing separate on and off command) this limits the ways I can program activities/marcos into a remote.
so, I am after a product that has:
- power plug
- at least 1 but better 2 or 3 power sockets
- ability to switch each and/or all power sockets on and off with discrete on and off commands from IR remote control
Does anybody know of a product that can do that or similar functinality? Or any other workaround?
EDIT: B&Q has ones with separate on and off commands, but they are RF, not IR. And all the IR ones I found are toggles only.
Looks like you want to control more than one socket, separately?
So for instance, the first Savasocket is programmed with one button on your remote, then with a second or third SavaSocket you can programme a different button for each.
Not quite separate on/off buttons, but do you really need that?
Light switches, wall sockets, Audio equipment, TV remote controls all work on principle of toggle for power buttons.
Hope that helps.
