power cables
ive read that it is wise to replace the mains power cable that comes with your tv so my question is - will i get better performance if i replace the mains power cable on my sky hd box?
if so can anyone recommend one?
cheers
Haven't tried, but I doubt it - and given that the Sky HD box uses a little 'figure of eight' mains connector, you won't find as many upgrade cables on offer.
thank you for your reply.
can you recommend an HDMI cable to use for connecting my sky hd box to my hd tv
thanks
QED's Qunex HDMI-P (£50 for a metre cable) should be ideal, assuming your set and box aren't a huge distance apart.
