Grimly Fiendish:aliEnRIK:
JohnNewman:
If the mains is dirty, then will the last meter of cable make a difference without a conditioner? (A question not a statement) :O)
As ive explained above (and tested for myself), BRAIDED cable cleans the mains interference (And means the longer the cable and the more the braids the better the effect!)
The only effect of these pieces of nonsense wire is the reduction of the quantity of money in your bank account which produces a proportional placebo effect.
Another person who truly doesnt have a clue
Lets put it this way. if it truly made no difference, or I was truly struggling to tell if it did or not...... id say so. Like today for instance, I bought some dual layer discs which havnt worked. I spent my money and they CLEARLY dont work. Do I feel foolish for saying so? No, I put it down to experience. SO, continuing from that, if the mains made no deifference at all, id say so, because I dont care one way or the other!
BUT
As it stands, the difference is EXTREMELY clear to see. If you havnt had much luck, or indeed just BELIEVE that mains cables have no effect than thats entirely your own experience.
Basically what im saying is that your wrong! But you believe what you believe mate. I care NOT a jot.........
