Power Amps
d_a_n1979
134
Right... Might be looking to build another system around an Arcam 9 integrated amp with my current B&W 602 S2 speakers that i have. Would the Rotel RB06 Power-Amplifier Power Amplifier be suited to the Arcam amp? I know most folks will say stick with the same brand but both amps will ne knocking out 70w per channel etc... Just want peoples views. Ta
Andrew Everard
1,878
If you want to use the Arcam as a preamp and the Rotel as the power amp, then yes fine, but one would have to ask why given that there's no power advantage.
If you want to use the Arcam and the Rotel together to biamp your speakers, just don't do it. Look for an Arcam power amp instead.
