Hi All
Just thinking out loud on possibly changing my set up, As you can see on my sig i have ATC gear which does sound superb once cranked up a bit which is something i rarely get to do. The ATC gear is very neutral and can be a bit cold at times and ruthless if its not a great recording. I'm starting to think i want something warmer and more musical, i want to listen to music, not analize and mix it!
I heard some Audio note AX-2 speakers on the end of a Croft integrated amp and it sounded amazing, i didnt want it to end, very rich musical, i'm starting to think that this is what i prefer, everytime i hear something similar i just wish i had that at home, the Croft, Audionote combo is something i am definately going to demo at home (although the speakers are not lookers).
Does anyone have suggesstions on a system change that might (speakers, amp or both) would be suitable and would high sensitivity speakers be better for lower level listening.
I also do a lot of listening on the headphones but i have no complaints there, the headphone stage on the ATC amp through my AKG's always sounds superb.
If anyone has any thoughts on this i would be truly grateful. I have been thinking about this for a while and is not going away!
Ed 🙂
Ed 🙂
