Polk React Volume problems
paul989
My Polk React soundbar frequently loses volume when switching between apps or using Alexa. The volume goes down to about 5% on its own. I'm considering taking it offline and just using the hdmi arc feature and see if that makes any difference in stability. Very annoying problem. I've tried everything else including factory reset and support doesn't seem to have an answer. Any ideas?
Hi there, sorry to say i have no idea personally id get straight on it polk or the dealer, they will be pest placed to answer your question and with a bit of luck get you back to just watching tv and listening to music. If not hopefully they can off you a solution
