PM6003 and CD6003 interconnect
McRagefit
Dear all,
Because of all the questions about cables lately, I thought to throw in my own question
I have the PM6003 amp connected to a pair of B&W685's using inakustik speaker cables.
My two sources, CD6003 and ST6003, are now connected to the amp using the standard interconnects that came in the box.
Would I gain much improvement in sound quality when I upgrade the interconnects? If so, which cables would be recommendable for my system?
I wonder how expensive the new ones should be to gain a noticable improvement in sound quality..
Thanks in advance!
Thierry
Thompsonuxb
129
Lol.... I'm asking for suggestions myself.
And yes interconnects make a huge difference. Maybe not seemingly dramatic instantly but over a long listening period they make or break a system. Between 20 to 40 english pounds is what you're most likely looking at initially. But more expensive does not always mean better ( according to taste).
Try a 20poundish cable to start , look at the buyers guide.
I've started with the Chord Crimson Plus £35 - but while clean I find they don't offer any 'connection' with the type of music I like - they produce a wall of sound imo. So if you like a "wall of sound"...er...sound, try them.
McRagefit
Thanks for the comment! I'm looking at the buyers guide now, but I'm still a bit puzzled about which type/brand of cables would fit my system.
Any general recommendations or remarks on that?
McRagefit said:
Dear all,
Thanks in advance!
Thierry
Hi Thierry
I'll recommend that you carry on using the basic interconnects supplied with the CD6003 and ST6003 :)
All the best
Rick @ Musicraft
Thompsonuxb
129
Honestly Cypher I don't think people give them enough. Although it will depend on how good your speakers are and the signal being sent, but cables really do make a big difference.
Cypher
156
We disagree but that's ok :)
Thompsonuxb
129
QED Performance 2 - 40 english pounds. Are an excellent interconnect
the cost of 2 and a half music CD's( full price) - worth it, honestly.
