MUSICRAFT:fowler:MUSICRAFT:
fowler:hi there,im currently using the chord cameleon silver plus analogue interconnects for my i30 and cd31 but id like to get the best out of them so can you guys reccomend me a decent xlr cable ? iv seen a krystal kable galaxy silver for £50 is this a good cable ? would it be a suitable replacement or better than the chord i already have ? thanks
Hi fowler
I have heard the Chord although not the Krystal Kable.
You may also want to consider Van Den Hul's Integration Hybrid. The Integration Hybrid is a cable that i have now mostly used (RCA and XLR) for nearly nine years at work and at home. The Integration Hybrid is my reference cable.
The Integration Hybrid at RRP is alot more money than the £50 for the Krystal however it is a worthwhile upgrade over the Chord.
Thanks for your support.
All the best
Rick @ Musicraft
thanks rick im hoping to pick some atc40's ex demo up after christmas im hoping you can help me? cheers david.
Hi David
Thanks for your post.
You are my customer so i'll go one better.
Anyway we'll talk later.
All the best
Rick @ Musicraft
cheers rick sounds good. im putting my atc11's up for sale at the begining of december to raise some cash, so i'll speak to you soon cheers david.
