- Aug 10, 2019
- 2,556
- 4
- 0
Ok - here's what I have: Onkyo TX-SR705, B&W 685 theatre package (685s front, 686s rear, HTM62 and ASW608). It's all brand new. For the last week I've been waiting for the 685s and the HTM62, but I just got them today. All the rest I've had for a week now, so was basically running a 2.1 system, with the 686s as the fronts and the ASW608 (which was working fine up until tonight).
Today, the rest of the kit arrived, so I moved the 686s to the rear and connected the 685s and the HTM62. I plugged the setup mic into the Onkyo, and when it came to putting a signal through the sub, nothing happened. At the end of setup, it said that no sub was detected.
I've double checked all the connections. The sub is powered by the outlet that's on the back of the Onkyo, using the 2-pin plug that came with the sub (rather than using the 3-pin plug and plugging it into the wall). It's connected to the subwoofer pre-out on the Onkyo using a Chord Crimson, to the Left line in on the sub.
I've tried the sub set to On, Auto and Standby - none of which makes any difference. The status light on the back just stays red, rather than going green when a signal is detected. There is no sound out of it whatsoever. I've tried manually setting the speaker config to "Subwoofer - Yes". Still nothing. As I've said, it was working fine for the last week.
One thing that has struck me is that the status light on the back seems to be more orange in colour all the time now - rather than switching between red for inactive and green for active. In fairness though, the orange thing might be just in my head - it changes a bit depending on what angle you look at it. It really doesn't seem as vivid a red as it was before though.
Anyway, I apologise for the length of this post, and I really appreciate you reading this far. If anybody can help me at all, please do - I really want to get this sorted out. I'd hate to think I'd been given a faulty sub.
Thank you so much,
John
Thank you so much,
John
