Plasma/LCD wall mount - what stops you using it for a bigger tv?
Juzzie Wuzzie
542
329
19,270
Let's say you have a 30-37" plasma/LCD wallmount. What stops you using it for say a 40/42" television? Assume that it is well bolted to the wall, so weight is not going to be an issue.
Basically whether the mount itself is strong enough to hold the TV, and whether the fixing points are adjustable enough to accommodate the greater size
