Pioneer LX50 or Marantz 6001
oldleodensian
44
Which is best for music? I want a DVD player that is multiformat for DVD-A and SACD, preferably with multi-channel sound output over HDMI...CD stereo sound better than a budget stand-alone would also be an advantage. So, not wanting too much for £200 then? yes, seen both for that bargain price!
If you can stretch to £250(previously £900) you could get an Arcam DV135 from superfi. This should blow either of the above out the water.
Hopes this helps.
Thanks, appreciate your response. Was seriously considering the arcam til I realised it only outputs DVD-A and SACD as 2 channel. As I aso own the normal CD versions of the SACD/DVD-A albums that I want to listen to in 5.1 surround, having the 5.1 version output as 2 channel is not really what I want.
