Phono to wireless to wireless to phono?
Andrew Everard
1,878
Like this, you mean?
nads
Ok had a look from else where.
Not really. Maybe my use of wireless is being confused with WiFi or access to a wireless net work.
what i am looking for is a way of wirelessly replacing a Phono cable. pre out to line in on different amps
Andrew Everard
1,878
Which is exactly what the BardOne does - wireless transmitter with stereo phono inputs, wireless receiver with stereo phono outputs.
Have one at home and it works perfectly.
Or am I missing something?
nads
I can find very little info on that Andrew.
Like do you need to buy two! or do both ends come for that price?
I think i will go for something similar from Audioengine the
Audioengine W1 at half the price (or is that a 1/4)!
mhoskins13
Hi Nads
I appreciate that this is a really old post of yours, but came accross if while searching for something similar.
I just wondered if this worked well for you. I am thinking of doing the same (i.e. wireless from Zone 2 on an Onkyo amp) to create a simple multi room set-up.
Any thoughts?
Michael
