Phono Pre-Amp for Rega P3-24/Elys2
trevoralves
39
Which Phono Pre-Amp would you recommend for a Rega P3-24/Elys2 turntable, please recommend one with and one without USB?
Without, I'd recommend the Cambridge 640c wholeheartedly.
With, I'd look first at the Pro-Ject Phono Box USB, though I've seen recommended the ARTcessories USB Phono Plus, which has more facilities (headphone monitoring for example) and one by Terratec. You might find you get just as good quality with a dedicated phono stage (see above) and a quality 2 x phono to mini jack into the PC, however.
Whichever solution you use, make sure you have a proper audio recording facility on your PC - XP didn't have one, and have never looked on Vista. A USB Phono Stage may come with the requisite software, but a colleague suggested one which splits tracks automatically - will ask which one he uses
Edit - lpripper or lprecorder - www.cfbsoftware.com.
Does anybody know whether the Project Phono Box with the valve output stage is any good? It looks quite impressive, but if I bought a Linn LP12 second hand would it suit the sound?
Thanks for you replies. How do you think the Cambridge 640P would compare against the Graham Slee Gram Amp 1?
