Panasonic TX37LZD81
Hi all,just joined the forum for some help. Just brought a Panasonic TX37LZD81 LCD TV with built in freesat. Can someone please tell me how to connect it up with my sky dish so i get both sky and freesat. At the moment i have the dish connected to the Tv not the sky box as there is a connection at the back of the tv for it. This gives me freesat ok but not sky. Take the sky dish connection back out and put it back into the sky box and this gives me sky but not freesat. Can anybody please give me some help as i am getting very frustrated. Thanks
kena
104
Can't do both together via same cable you need another cable run from your dish LNB to TV Freesat socket.
Andrew Everard
1,878
If you just have a basic Sky box, you'll need a dual LNB on the dish, and a another run of cable, as kena says.
If you have Sky+ or Sky+HD, or are planning to get either of those, then you will need a quad LNB, and three runs of cable, as the twin tuners in the Sky+/Sky+HD boxes each need their own feed.
Thanks for your help. Will have to get in touch with a satalite installer then.
