Panasonic TX-32LXD700
Probably a stupid question so pardon my ignorance but what's the difference between the 700 and the 70 models panasonic produce. I note the 700 had superior sound and an extra HDMI but is that it? And is that worth an extra £90?
Cheers,
Alex
Andrew Everard
1,878
To be honest, it depends how much of the time you'll be listening to the TV's own speakers, and whether you have more than one HDMI-equipped component to hook up.
If so, then yes it may well be worth it - but if you're going to be using it with a surround sound system able to take several HDMI inputs and feed them via a single cable to the TV, plus give you much better sound, probably not.
