Panasonic SC-PTX5EB-K
I am considering buying a Panasonic SC-PTX5EB-K Home cinema system and was wondering if anybody had tried it out?
Can't find any reviews anywhere.
I like it, it sounds nice. Mind you though, I haven't heard it with a movie playing, just only heard it with a stereo cd. It sounded quite good, I wasn't blown away by the sound quality but for a system with such small speaker it sounds pretty good.
I'm not going to recommend it to you if you have a big living room though, it didn't have loads of power. For small to middle sized living rooms it should suffice though.
Thanks for you help. My living room is pretty small so it should probably do fine.
