Panasonic Green Light Flashing On Power-Up
Sizzers
188
Had the Panasonic TX-P42GT30B for a week, and when I turn on the TV the relay clicks in and the green LED rapidly flashes for a few seconds before holding then the picture comes on.
Is this normal? I've not been able to find anything elsewhere specific to this so guess I'm just looking for a bit of reassurance.
Many thanks,
Malc.
My 2011 TX-L32U3B does the same thing so if it's standard across the panny range then yes, I think it's probably normal.
Sizzers
188
Thanks a lot guys!
This is my first ever Panasonic TV and every time I switch it on I keep thinking it's not going to make it! Wish they'd put this in the manual to allay any uneccessary worries.
Oldboy
421
:grin:
Of course i would have told you if i thought it was unusual but fortunately that's not the case, hopefully you get through the run in soon and are able to enjoy the tv to the full.
