Can anyone suggest the best way of painting some tatty speakers. I want them white and are probably going to be used for the kitchen. Is normal gloss white paint okay to use or emulsion? They have a thin coating of vinyl on them. Do I need a primer first?
I don't intend to paint around the cones just over the front grille. Maybe a white spray would be best to coat the cloth grille?
