Overhang gauges and Alignment protractors
pegleg1945
17
On the subject of the above tools,should we have both of these when changing a cartridge.
I know the importance of the correct overhang but is a cartridge alignment protractor 100% necessary,and if it is then what's the best type,( I have a Technics sl-d2).
Thanks in advance
pegleg1945 said:
Thanks in advance
A correctly aligned cartridge is a must. The are some alignment protractors that do both jobs. The best are expensive but you can pick up mirrored contractors pretty cheaply. It depends on how much you want to spend.
You'd only need a basic protector for your turntable.
chebby
1,253
26
19,220
I've met one. They are pretty reflective types ...
GeoffreyW
189
28
18,620
Don't forget to visually check that the stylus is actually vertical when sitting in the groove, after you check the other alignments. I had to shim my cartridge in the headshell (thin strips of thin plant label) as the headshell azimuth was out of true, with no adjustment available. If you place the stylus into a groove of an LP with the platter static, just confirm either that the cartridge body is parallel horizontally to the record, if you can, or just look at the stylus itself.
