Output from PS 3 to Sony STR-DA2400ES
What is the best connection settings for the PS3 when connected to the STR-DA2400ES, should this be bitstream or PCM?
Assuming you have the older 'fat' PS3, for Blu-Rays PCM is best to allow the PS3 to decode the HD audio formats onboard. For DVDs, it's up to you, bitstreaming will send the Dolby Digital / DTS soundtracks for the amp to decode, PCM will decode them onboard.
If you have the new 'slim' PS3, again it's up to you but most people believe bitstreaming to the amp is best for everything.
Thanks for the advice, why dont they put this sort of thing in the instruction manuals - would make it alot easier!
Thanks for the advice. Why dont they put this sort of thing in the instruction manuals, would make life alot easier!
Cheers.
