If thats only a transport how does it play movies?.. Would a video converter not be needed?.. Not really should how this one works.gel said:
A blu ray transport does not decode audio. It will send the codec uncompressed to the AV receiver to decode audio. Most of us bitstream audio to the AV receiver anyway.Native_bon said:If thats only a transport how does it play movies?.. Would a video converter not be needed?.. Not really should how this one works.gel said:
I was actually referring to video conversion not sound.bigboss said:A blu ray transport does not decode audio. It will send the codec uncompressed to the AV receiver to decode audio. Most of us bitstream audio to the AV receiver anyway.Native_bon said:If thats only a transport how does it play movies?.. Would a video converter not be needed?.. Not really should how this one works.gel said:
Denon has released blu ray transport players in the past, and I think so did Marantz.
Not sure what you mean by "video conversion". It will process video.Native_bon said:I was actually referring to video conversion not sound.bigboss said:A blu ray transport does not decode audio. It will send the codec uncompressed to the AV receiver to decode audio. Most of us bitstream audio to the AV receiver anyway.Native_bon said:If thats only a transport how does it play movies?.. Would a video converter not be needed?.. Not really should how this one works.gel said:
Sounds quite good if my Pioneer bdp-lx71 breaks I will probably buy it. I am done with 4K.bigboss said:Not sure what you mean by "video conversion". It will process video.Native_bon said:I was actually referring to video conversion not sound.bigboss said:A blu ray transport does not decode audio. It will send the codec uncompressed to the AV receiver to decode audio. Most of us bitstream audio to the AV receiver anyway.Native_bon said:If thats only a transport how does it play movies?.. Would a video converter not be needed?.. Not really should how this one works.gel said:
According to product page:
The OPPO BDT-101CI is a reliable and versatile Blu-ray transport designed for Custom Integration. With a robust feature set distilled from the award-winning BDP-103/105 series and advanced video processing technology, the BDT-101CI offers excellent audio and video performance and is simple for custom integrators to install and support.
While OPPO Blu-ray players have been widely used by custom integrators, the rich array of features such as Internet streaming apps and extra audio/video inputs are often reasons for frequent support calls from customers who are not very tech-savvy. Many installers have asked for a model that has the audio video performance and disc compatibility of the BDP-103/105 series, but without the extra features that are either duplicated by other components in a custom integration project, or not required by their customers. The BDT-101CI is the answer for such demands of the CI community.
So Oppo are saying all 3 Oppo Blu Ray players have the same picture quality.bigboss said:Not sure what you mean by "video conversion". It will process video.Native_bon said:I was actually referring to video conversion not sound.bigboss said:A blu ray transport does not decode audio. It will send the codec uncompressed to the AV receiver to decode audio. Most of us bitstream audio to the AV receiver anyway.Native_bon said:If thats only a transport how does it play movies?.. Would a video converter not be needed?.. Not really should how this one works.gel said:
Yes they do have the same picture quality, its only the Audio parts that are different. Yes Oppo is a good all rounder, or should I say it was. Its a very good transport but the dac on the Oppo is not that special anymore. Curently using my Oppo as transport for a new Chord 2Qute which am trying in my system. The Chord is a revelation as per what a dac can do.bigboss said:They've always maintained that 103 and 105 have the same picture quality.
gel said:Sounds quite good if my Pioneer bdp-lx71 breaks I will probably buy it. I am done with 4K.bigboss said:Not sure what you mean by "video conversion". It will process video.Native_bon said:I was actually referring to video conversion not sound.bigboss said:A blu ray transport does not decode audio. It will send the codec uncompressed to the AV receiver to decode audio. Most of us bitstream audio to the AV receiver anyway.Native_bon said:If thats only a transport how does it play movies?.. Would a video converter not be needed?.. Not really should how this one works.gel said:
For some reason I missed your reply BB. Yes I have read about the BDT-101CI now. Sounds like a good cheaper substitute. If I was buying new properly would have picked one up.bigboss said:Not sure what you mean by "video conversion". It will process video.Native_bon said:I was actually referring to video conversion not sound.bigboss said:A blu ray transport does not decode audio. It will send the codec uncompressed to the AV receiver to decode audio. Most of us bitstream audio to the AV receiver anyway.Native_bon said:If thats only a transport how does it play movies?.. Would a video converter not be needed?.. Not really should how this one works.gel said:
Why?gel said:Sounds quite good if my Pioneer bdp-lx71 breaks I will probably buy it. I am done with 4K.bigboss said:Not sure what you mean by "video conversion". It will process video.Native_bon said:I was actually referring to video conversion not sound.bigboss said:A blu ray transport does not decode audio. It will send the codec uncompressed to the AV receiver to decode audio. Most of us bitstream audio to the AV receiver anyway.Native_bon said:If thats only a transport how does it play movies?.. Would a video converter not be needed?.. Not really should how this one works.gel said:
*ROFL* *ROFL*bigboss said:Why?gel said:Sounds quite good if my Pioneer bdp-lx71 breaks I will probably buy it. I am done with 4K.bigboss said:Not sure what you mean by "video conversion". It will process video.Native_bon said:I was actually referring to video conversion not sound.bigboss said:A blu ray transport does not decode audio. It will send the codec uncompressed to the AV receiver to decode audio. Most of us bitstream audio to the AV receiver anyway.Native_bon said:If thats only a transport how does it play movies?.. Would a video converter not be needed?.. Not really should how this one works.gel said:
Yep, but have decided to keep it for 1080p, and Sky.buzz_lightclick said:gel said:Sounds quite good if my Pioneer bdp-lx71 breaks I will probably buy it. I am done with 4K.bigboss said:Not sure what you mean by "video conversion". It will process video.Native_bon said:I was actually referring to video conversion not sound.bigboss said:A blu ray transport does not decode audio. It will send the codec uncompressed to the AV receiver to decode audio. Most of us bitstream audio to the AV receiver anyway.Native_bon said:If thats only a transport how does it play movies?.. Would a video converter not be needed?.. Not really should how this one works.gel said:
is that why you briefly had your E6 up for sale on AV Forums and eBay over the weekend?
4K is no better than Blu Ray, I never watched a 4K Blu Ray much so sold all my 4K Blu Rays and 4K Blu Ray player, the Oppo interests me but I probably won't buy it.bigboss said:Why?gel said:Sounds quite good if my Pioneer bdp-lx71 breaks I will probably buy it. I am done with 4K.bigboss said:Not sure what you mean by "video conversion". It will process video.Native_bon said:I was actually referring to video conversion not sound.bigboss said:A blu ray transport does not decode audio. It will send the codec uncompressed to the AV receiver to decode audio. Most of us bitstream audio to the AV receiver anyway.Native_bon said:If thats only a transport how does it play movies?.. Would a video converter not be needed?.. Not really should how this one works.gel said:
Me too.Native_bon said:For some reason I missed your reply BB. Yes I have read about the BDT-101CI now. Sounds like a good cheaper substitute. If I was buying new properly would have picked one up.bigboss said:Not sure what you mean by "video conversion". It will process video.Native_bon said:I was actually referring to video conversion not sound.bigboss said:A blu ray transport does not decode audio. It will send the codec uncompressed to the AV receiver to decode audio. Most of us bitstream audio to the AV receiver anyway.Native_bon said:If thats only a transport how does it play movies?.. Would a video converter not be needed?.. Not really should how this one works.gel said:
gel said:4K is no better than Blu Ray, I never watched a 4K Blu Ray much so sold all my 4K Blu Rays and 4K Blu Ray player, the Oppo interests me but I probably won't buy it.bigboss said:Why?gel said:Sounds quite good if my Pioneer bdp-lx71 breaks I will probably buy it. I am done with 4K.bigboss said:Not sure what you mean by "video conversion". It will process video.Native_bon said:I was actually referring to video conversion not sound.bigboss said:A blu ray transport does not decode audio. It will send the codec uncompressed to the AV receiver to decode audio. Most of us bitstream audio to the AV receiver anyway.Native_bon said:If thats only a transport how does it play movies?.. Would a video converter not be needed?.. Not really should how this one works.gel said:
