open, dinamic, clear sounding budget stereo amp for my Quad speakers
Tibor
59
I looking for a budget stereo amlifier (max. 300 pound) for my Quad 11L Classic speakers/Arcam CD 72 system. I should replace my Arcam Alpha 7 amlifier, which has problem with volume knob and it has some humming sound.
I need an open, fast, a little bright sounding amlifier, wich will mach with warm sounding Quad speakers. I mean more open and transparent sound than for examle. Nad 316BEE/326BEE or my Arcam Alpha 7 have.
Thank you for suggestions
Tibor
59
Thank you for all, sorry my budget (max 300 pound /400 euro) is not enough for modern Arcam, Quad and Creek amps.
So the question is Denon PMA 720 or Pioneer A 30? (no possibility for listening tha amps)
Yamaha S 500 as new is too expensive in my country
I would prefer the clearer, less warm and more hifi one.The point is more detail, and a brighter, but not harsh sound
Vladimir
220
7
Go to a Hi-Fi shop and place your hand on top of these amplifiers, and the one that goes warm the most, will sound warmest of the group.
Thompsonuxb
129
Try eBay or one of the other internet sellers.
You could get a Arcam 19 or a Rotel ra-12 or a Rotel ra-1520 for about that price. All around the £600 to £750 mark.
The Rotels take an age to settle in (something I have learned) but deliver the sound you discribe.
And will drive the Quads well. But that's the price range your speakers deserve.
Or you can order a Yamaha as-500/501 online from a British store like Richersounds, p&p may have to be added to your budget though.
Thompsonuxb
129
Tibor said:
  Yes !, used Rotel is a good idea
Lol, forgot to add 'but go for around your budget'
If you get a hardly 'used' Rotel chances are its 'just' breaking in.....impatient owners.
I was surprised by the brand.
matthewpiano
Rotel is a very good call. I once had Rotel RA-01 with Arcam CD73T and Quad 11L and it gave exactly the sort of sound you seem to be looking for. Very clear, very 'hi-fi', excellent seperation and soundstaging, good dynamics, and good timbral accuracy. It was open sounding without veering into screechy upper strings. One of the better of my previous systems, and certainly one of the best outcomes I heard with the Quads.
Either look for a good 2nd hand Rotel, or consider a new RA10. If you can find a 2nd hand Rega Brio-R, that would be even better.
Tibor
59
Thank you for sharing your experience. Unfortunately there are very few Rotel or Rega amps on ebay. ( I live outside of UK)
What is your opinion about Denon PMA 720 AE ?, it has a similar clear and vivid sound like aforementioned Rotel RA-01?
Vladimir
220
7
You can buy a toy amplifier if new or a serious one second hand for the same money. Denon PMA 1500 AE sells for 400 euros second hand in Europe and that is a MUCH better amp than anything we mentioned so far.
Tibor
59
I am from Hungary, I will take look at used hifi market (online)
drummerman
540
+1
I owned one for quite some time. Good and sounds powerful but bass can be a little loose/dominant with the wrong speakers. Cyrus was quite a big improvement overall (imo)
Vladimir
220
7
drummerman said:
+1
That brutish Ultra High Current Mosfet circuit is to blame. I think it will suit the OP more than Rotel according to his description.
Thompsonuxb
129
Vladimir said:
drummerman said:
+1
You should follow that Rotel link/thread through before turning into a synergy then cable thread, long run in for Rotels get a mention
Vladimir
220
7
How long before it grows another transformer and twice the capacitance?
