Online Storage to stream my own music
dan2503
Firstly apologies if this is the wrong forum....but I couldn't find one specific.
I am looking for 'cloud storage' that I am able to stream back to my phone. I have hundreds of lossless files stored on computer but it would be nice to store them remotely. Firstly, so I'm able to play them back via any device, anywhere and secondly as security should anything happen to my computer.
There may be an obvious answer but I can't find it without constantly finding Google and iTunes.
Anderson
You could rent s VPS with whatever amount of disk space you require, set up a music server of some description.
What I do is upload my Music to Google Play so that I can stream where ever I want with an internet connection.
Google Music is probably coming up a lot because it works, is useful and free.
jjbomber
It's about £120 for a 3TB version. you then use to app to listen to your music worldwide. It is very simple to set up and use. Just copy the files from the PC to the my cloud and away to go.
MajorFubar
690
I'd been thinking of doing this with my own lossless files and coincidentaly enough I raised a similar thread about it last week. However currently I've found my internet connection cripples the practicality of doing something which in theory at least should work: after an hour I was still waiting for one CD to upload to the cloud, and I've ripped over 640 of them. Maybe I'll have another go when I eventually get fibre.
Xanderzdad
146
If you use a Synology NAS then it allows access to your music (and video's & photo's) from anywhere in the world via a brilliant app called DS Audio. Obviously a housefire would destroy it (unlike the cloud) but a fireproof safe is quite cheap.
No uploading needed. You can store files off-line on your phone or stream direct to it.
Wuss
7
I use a QNAP TS221 Nas box. It gives me access to my FLAC files anywhere in the world via QNAP Cloud (Free). Last year I was on holiday in Florida sitting in my Villa listening to my music via the Qnap Musi App. Not bad for 3000+ miles.
