ONKYO 875, PS3 and RSW12 setup issues - Andrew grateful for your input please.
Finally managed to get the equipment all set up in following configuration:
RS6 Bi-amped to 875
RS Center Bi-wired to 875
RS1 connected to rear outputs on 875
RSW12 Connected to Sub Output on 875
PS3 Conncted to 875 via HDMI.
Have set everything up as per manuals (RSW12 low pass filter off etc), however even with RSW12 volume set quite high I am getting very little from it. It does react to explosions in films etc however at that volume I'd be expecting the house to shake rather then the low rumble I am currently getting. Have checked LFE settings on 875 and they are all set to 0db as default so doesn't appear to be a problem there? Not sure if I'm doing anything else wrong or it the Bi-amping is causing a problem?
Any ideas?
What level is the sub volume channel on the amp set to, mines around +3db. Is the amp crossover set right, maybe 60 or 80hz? Did you use Audyssey to set the levels, it put the sub level LOW on my Denon 3808.
Rob
